Witam, wrzucałem już mój log do tego tematu
viewtopic.php?f=2&t=13556 ale nikt mi nie odpowiedział. Więc zakładam nowy temat
Podpiąłem moją fabie 1,4 mpi do vaga i dałem w programie auto-scan. I otrzymałem taki raport:
VAG-COM Version: Release 311.2-N
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: TMB NH2 6Y4 235
Component: 34112 SKZ7Z0B1394506
5 Faults Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-00 - -
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-00 - -
16556 - Fuel Trim: System Too Rich: Bank 1
P0172 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0110 0101
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 G
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 13765
1 Fault Found:
01314 - Engine Control Module
79-00 - Please Check Fault Codes
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 09242
Shop #: WSC 13765
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 15 -------------------------------------------------------
Controller: 1C0 909 605 H
Component: 08 AIRBAG VW51 08 0004
Coding: 00515
Shop #: WSC 68102
1 Fault Found:
00655 - Seat Belt Tensioner Igniter: Passenger Side (N154)
32-10 - Resistance too High - Intermittent
Address 17 -------------------------------------------------------
Controller: 6Y1 919 880 C
Component: KOMBIINSTRUMENT VDO V11
Coding: 16141
Shop #: WSC 75008
TMBNH26Y423534112 SKZ7Z0B1394506
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0909901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 13765
3 Faults Found:
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 R
Component: LenkhilfeKYO V913
Coding: 10111
Shop #: WSC 31414
No Faults Found
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 H
Component: 2Q Komfortgerát 0001
Coding: 00067
Shop #: WSC 13765
Note: Can't Synch Baud Rate
End -------------------------------------------------------
O ile wiem to żeby skasować te błędy to trzeba po kolei wchodzić w poszczególne sterowniki i kasować. Ale czy te błędy są jakieś poważne i czy mogę je spokojnie bez ryzyka skasować? Bardzo męczy mnie to:
Coding: 00515
Shop #: WSC 68102
1 Fault Found:
Cały czas świeci się kontrolka poduszek powietrznych. Jak sobie z tym poradzić? Inne problemy to duszenie się silnika ale tu będę czyścił przepustnice bo czytałem już różne topiki na forum i stąd chyba te początkowe błędy.
Proszę o pomoc:)
