skoda fabia 1.4 mpi co to za bledy??
witam podlaczylem dzisiaj fabie pod vag i wyszlo mi takie cos
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 047 906 033 D
Component: 1,4l SIMOS3PB 00HSSJ33
Coding: 00021
Shop #: WSC 13765
TMBNH46Y023471263 SKZ7Z0A1257893
1 Fault Found:
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-10 - - - Intermittent
Readiness: 0110 0101
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 09242
Shop #: WSC 13765
1 Fault Found:
01598 - Drive Battery Voltage
07-00 - Signal to Low
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Y1 919 880 C
Component: KOMBIINSTRUMENT VDO V10
Coding: 16141
Shop #: WSC 00001
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
wiem tylko ze ten blad 00779 to Czujnik temperatury zewnętrznej – G17
i mam czasem dziwne akcje ze stoi w garazu a pokazuje mi -45 stopni prosze was o pomoc
